1 - 6 of 6 Posts
I accidently deleted the conifg file for CS:S. I am updatign CS:S right now but when it completes will it create another config file or wil i have to make a new one? and if i make a new one how do i do that?
lmao...how did you manage that? it should create a new one, just go to the file menu or whatnot and look for something that says verify files and it will replace any missing files.
well th eproblem was the resolution was 2 high adn my monitor wont see it so i deleted the config files adn now haev to update it. so i guess i actually didnt "accidently" delete it.
ask your friends or mIRC or something if someone can send you the default config and i will be alright , or you could re-install steam and download source from steam servers again!
1 - 6 of 6 Posts
