1 - 6 of 6 Posts
My fathers netbook doesn't start up anymore. It begins to boot and then restarts and continues to do so. He says he was just web browsing and then this happened. No data needs to be saved. Any solutions? I wanted to avoid format if possible but if that is the only way I guess I will do it.
Are you hating on Acer or just good sarcasm? I am not saying I am any fan of acer but it is just a little netbook for work and home. Like I said I do not even use it. I would just appreciate if anyone knew any solutions.
lol i am but i will help lol i just had bad experience after bad experience with there support anyways does it make it to windows or is bios rebooting?
no windows restarts you need to reinstall... or check to make sure its cooling properly. take the back plate off and clean out the heat sink. It will be near teh outside
1 - 6 of 6 Posts
