1 - 12 of 12 Posts
Some early sites says that title monitor can handle with G-Sync 75Hz. Can some user confirm that?
I ordered that monitor yesterday and have it on next week. On some youtube video user cant change it to 75Hz, we had try to resolve is it even possible or not to have 75Hz?
Our conversation find here:
Yes I have the XB271HK, just got it last week from provantage. I cannot get it to run even at 61hz, let alone 75. This is with GSync on or off. Also, I tried 2 certified DP 1.2 cables.
How are you finding the monitor? I'm a little astonished by how little talk there is on this unit.
It's available on ProVantage for $820 right now. http://www.provantage.com/acer-um-hx1aa-002~7ACEP0FJ.htm
Discussion Starter #4
1.5 week here also 271HK now. Its only 60Hz, even panel manufactor (AUO) info says its only 60Hz, i hoped that G-Sync v2 could possible overclock panel, like a 3440x1440 [email protected]
I bought my monitor from national re-seller, here Finland. Tilde88, what's yours monitor firmware?
Discussion Starter #5
Factory Menu: Turn monitor off > Push most left button and keep it down > Turn monitor on (still keeping left button pushed all time) and monitor starts and factory menu opens.
Heres my info:
Discussion Starter #7
Thru that Custom resolution i tryed. Also i try CRU, no help. Tryed 61,63,65,68,70,71,75Hz and monitor says: No Signal.
I have also drivers (whql361.43) on nVidia Monitor OC patched. On NCP i try also all timings @61Hz.
Discussion Starter #9
Checked that week ago, there are no OC enable section like a X34 has.
- 1920x1080 @60Hz, not even 61Hz
- 1024x768 @64Hz
- 800x600 @67Hz WOOOA
- 1024x768 @64Hz
Yeah, but other than that how's the monitor? Do you recommend it?
Discussion Starter #11
For 4K playing with nVidia GPU, definetly. With G-Sync (on nVidia display adapter).
But on with AMD GPU, not. GSync becouse of course its pointless with AMD GPU. NOT. 4K still needs a GSync/FreeSync.
1 - 12 of 12 Posts
