1 - 11 of 11 Posts
ShakinHips
Have an
Acer Aspire Timeline M5-581T
I have looked around the interwebs and the better place for replacements
Laptop Replacement Screens- SOLD OUT
The screen that is currently in the laptop is destroyed. Needs to be replaced.
Ebay is not turning up any results for me whatsoever.
Help searching would be great.
OH and warranty doesnt exist for the laptop anymore. I have called support and they said it would be almost 200 bucks for replacement. And i would have to send it in for a month to be worked on. Asked about getting the screen only and they said you would have to call this place shopbysystem.com...I called no answer all day have been calling no answer what soever.
So ya im going to freak out. The rest of the laptop is fine boots up (hooked it up to a second monitor to make sure). Runs perfectly fine just the screen is kaput
You might have better luck if you remove the broken panel and get the mfg. and part number of the panel being used. Since panels are a commodity now, there are likely several other brands and model numbers that are using the same or compatible panel.
Just a thought.
The other thing you might try is to contact ScreenTek and see if they can point you to an online retailer that stocks your particular screen. ScreenTek is a panel wholesaler and it is the same place that many repair shops and etailers source their replacement panels from.
1 (855) 289-7854
Reactions: odin2free
ShakinHips
AWESomo3000
i will get this done now lol
have more projects on my plate blah (said i would repair five iphones and what not then they want me to upgrade the computers and fix things haha all the other stuff i have found easily but this screen is a pain in the neck as you said its a commodity)
Thanks
I will return with mfg and part numbers...I think the screen is LG but im not sure will see
Ok so these are the numbers i have pulled
The green control chip (where the power is sent through along with webcam is sent to)
Hologen Free LG Dispaly
P/N: 6870S-1418A
Desc: LP156WH6TJA1
This is the Screen it self
Lucom Display- F2156WH6
LK1560801922100C04160A
F2156WH6-A20AG0-A
EDIT: Called Screentek
Not available nor do they know anybody at all. its a rare screen
Ugh the hunt conitues on to ebay. and on to foreign sites (wholesales no buenos)
ShakinHips
Discussion Starter · #6 ·
Here is the back of the screen...
It has a webcam and the power female connection for the webcam on the pcb
https://imageshack.com/i/nmdz6hj
The screen i believe is distributed by lucom and is LG specific
I did remove the webcam and the cables for the screen.
I do know to that the screen is 1.7mm in depth...So there are only three others that i saw on panelook that would be related or similar
Rare screens lol
Well crap Odin. Doing my best to help but keep striking out............... Sorry about that.
ShakinHips
Discussion Starter · #8 ·
All night last night was the same feeling as you lol. Just like dang it janet.
thank you for all the help. I was up for a good while looking up as much as i could but said eff it. Owner is ok with just using an external montitor via hdmi for basic stuff nothing to crazy. He was not even bringing it anywhere with him at all.
Thank you again.
Hello ODIN,
i'm same as you, did u find a new screen ?
I'm still looking for it, but using the computer as desktop laptop with monitor is a shame!!!!
I'm actually doing this, but u have to know the graphic card in this computer working only with the screen it self!!!
It's have 2 graphic crad, one intel slow used for low jobs, and Nvidia working for games. It s automaticaly dectecting wich graphic card to use...
So if u put your computer on TV screen, u will never use u re Gforce graphic card cause it CAN'T WORK with HDMI out
I would be glad if u could answer me if u had found a new screen under 100$ !!! cause i have found it about 300box as LTdan83... considereing th eprice of the computer... it s not worthing it !!!
I will let u know if i find someone selling it !!!
Enjoy !!
1 - 11 of 11 Posts
