ACER XF270HU AHVA 144 Hz Freesync Owners & Discussion Thread
PC Monitors - November 25, 2015
Product Specs
Freesync™
Freesync™ Enhancements:
Places to buy ( Normally $599.99 )
Amazon
Walmart
Provantage
Acer - UK
FOUR! USB 3.0 ports, needing extra VR hook ups anyone?
Quote:144Hz AHVA (IPS-type) panel with a 2560 x 2440 (WQHD) resolution.
144 Hz Monitors - November 6, 2015Although the shape and general design is similar to the XB270HU, matte rather than glossy plastics are used for the bezel and stand.
Source - PC Centric100% of the sRGB color spectrum is covered by this display and with the Flicker-Free technology, you won't experience eyestrain after longer periods of usage. The monitor is also equipped with Blue Light Filter technology.
Product Specs
- eColor Management
- Acer Adaptive Contrast Management (ACM)
- 100% sRGB color gamut
- Mercury free
- Flicker-Less technology
- Low Dimming technology
- 6-axis color adjustment
- Blue Light Filter technology
- FreeSync Technology
- Horizontal Viewing Angle: 178
- Display Type: LED-backlit LCD monitor / TFT active matrix
- Response Time: 4 ms (gray-to-gray)
- Aspect Ratio: Widescreen - 16:9
- Color Support: 16.7 million colors
- Brightness: 350 cd/m2
- Screen Coating: Anti-glare
- Portrait / landscape mode
- VESA interface support
- Dimensions (WxDxH) With stand - width: 24.6 in - depth: 9.6 in - height: 15.8 in
- Dimensions (WxDxH) Without stand - width: 24.6 in - depth: 2.5 in - height: 14.6 in
Freesync™
- Minimum/Maximum display rate is now listed in Radeon Settings
- Low framerate compensation to reduce or eliminate judder when application FPS falls below the minimum refresh rate of an AMD Freesync™ enabled display
- New support for AMD Freesync™ with AMD Crossfire™ in DirectX 9® titles
Amazon
Walmart
Provantage
Acer - UK
