1 - 18 of 18 Posts
Hi<br><br>
I went to the chemist to get some acetone to clean off my CPU and HS. It says 100% acetone on the front. But when I got it home on the back in small print for the ingredients it has "acetone, perfume". Is it ok to use this stuff to clean my CPU? Will the perfume leave any residue? <img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused">
I use 90% isopropyl alcohol.
Go pick up some 91% isopropyl alcohol.
<tr>
<div>
Originally Posted by <strong>leimrod</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1389061#post1389061" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Hi<br />
<br />
I went to the chemist to get some acetone to clean off my CPU and HS. It says 100% acetone on the front. But when I got it home on the back in small print for the ingredients it has "acetone, perfume". Is it ok to use this stuff to clean my CPU? Will the perfume leave any residue? <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>Ask the chemist about it. Where did you find a chemist anyway?
At the local chemist/crystal meth dealer.<br />
<br />
Can't you buy acetone from a hardware store or paint store?
please be advised..as a chemist I can tell you that companies advertise many things as 100%...if there is a single aditive, it is obviously no longer 100%...if it has an added ingredient, but yet still claims to be pure, then the added ingredient must be in amazingly minute quantites....yet for purposes such as you intended, you would be advised to use alcohol.
<tr>
<div>
Originally Posted by <strong>rabidgnome229</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1389833#post1389833" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Ask the chemist about it. Where did you find a chemist anyway?</div>
</td>
</tr>
</table>
</div>a chemist is what they call a Pharmacist i'm pretty sure.
what cgrado said<br />
<br />
do you americans take a chemist to be an individual involved with chemistry?
<tr>
<div>
Originally Posted by <strong>tUDJ</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1389884#post1389884" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">what cgrado said<br />
<br />
do you americans take a chemist to be an individual involved with chemistry?</div>
</td>
</tr>
</table>
</div>yep. but i've heard enough brits talk about chemists being a pharmacist to know what he's talking about.
Acetone owns alcohol in removing hard to clean stuff. But if its not pure acetone, its still ok to use, just use alcohol afterward to remove any residue.
<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Discussion Starter #13
ok been down to the local DIY and they haven't even heard of Isoprophyl Alcohol. They pointed me towards Methylated Spirits and White Spirits? Just as a question, can I use Meth/White Spirits to clean as well, what is the main difference between them and Isoprophyl Alcohol?<br><br>
Also on the matter of Acetone, somebody was telling me its pretty hard to get pure acetone here, something to do with it being a key ingredient in TriAcetone TriPeroxide explosive. I don't know how true this is but I wasn't able to find any pure acetone in the "pharmacy" or DIY store.<br><br>
What about the alcohol cleaning pads they have in pharmacys, are they pure alcohol?
I would still just use Isoproprphyl Alchohol. You can get it at Walgreens if there is one in your area. Its just alcohol but 91%. I think you can in fact use spirits but I dont think it will do a good job. Also you can use Tequila if you have any around or any other strong alcohol.<br><br>
Also we still call them a Pharmacist here not a Chemist, but it may very per state.<br><br>
pink
<tr>
<div>
Originally Posted by <strong>Mr Pink57</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1391235#post1391235" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">I would still just use Isoproprphyl Alchohol. You can get it at Walgreens if there is one in your area. Its just alcohol but 91%. I think you can in fact use spirits but I dont think it will do a good job. Also you can use Tequila if you have any around or any other strong alcohol.<br />
<br />
Also we still call them a Pharmacist here not a Chemist, but it may very per state.<br />
<br />
pink</div>
</td>
</tr>
</table>
</div>I dont think Walgreens has invaded Ireland yet
You need some 99.9953% Isoproply Alcohol: <a href="http://www.mgchemicals.com/products/824.html" target="_blank"> Here</a><br />
<br />
Really all you need is 91% or higher Isoproply, like under a euro at your 'chemist'.<br />
<br />
I know you can't buy from newegg, but this stuff is found everywhere:<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835100010" target="_blank">http://www.newegg.com/Product/Produc...82E16835100010</a><br />
Good too.
55 gallons? who buys 55 gallons of that stuff?
<tr>
<div>
Originally Posted by <strong>cgrado</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395681#post1395681" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">55 gallons? who buys 55 gallons of that stuff?</div>
</td>
</tr>
</table>
</div>Bunk discount ^_^<br />
<br />
The 500ml bottle at the computer shoppe here is $10... an oil drum of it would be like $4,000.
1 - 18 of 18 Posts
