1 - 2 of 2 Posts
I understand the process for flame polishing clear acrylic edges. Haven't mastered it but doing okay. My question is can this be done to non-clear acrylic/plexiglass? I'm using both clear and black acrylic. I can get the clear acrylic edges to shine but not so with the black. On the black, I'm just trying to tone down or eliminate the table saw markings. Thanks for any suggestions.
Overclock Failed...
Have you tried adding a stabilizer plate to you table saw?
A router makes much cleaner cuts which are then much easier to polish.
1 - 2 of 2 Posts
