1 - 20 of 4,352 Posts
Discussion starter · #1 ·
This thread is a brief how to on bending acrylic pipe and the basic use of a former.
First up is the basic kit we need.....(Magoo optional)
We have a heatgun,tube,silicone fuel line that has an OD matches the ID of the tube you wish to bend and a former....the square is for checking the 90 bends on the former.
So,the former,in this case a 2" wide piece of sheet alu rolled over a deodarant can to get a radius,you can select anything with a diameter of 40mm or over,thick walled tube will need a larger radius to prevent kinks.
The line is the bend start,this will become clear in a minute
The beauty of this is that you can form any specific angle you like and bend tube to it.
For instance: You have 2 ports you wish to join on the same plane,you can form the pathing from the inner measurement between the ports and bend a former to suit. Measure the closest points between the fittings from the actual tube insert point,bend the former so the 2 faces on the 90s match the gap and Bob is indeed your uncle
The silicone fuel line.
This needs to be around .5mm smaller that the ID of the tube you are bending
Normally used for RC cars,chosen for its high melt point and great flexibility.
The small cut line round the tube is placed at the start of you bend and is the reference point for another way of doing point to point bending.
Remember the pencil line on the former? Well,put the cut line of the silicone tube on that ref point when doing the bend and you will get consistent bend radius measurement.
Like this.
For example: I want to tube 2 ports 150mm away,inlet to inlet on the inner points,I know that a bend will have a measurement of 20mm from that mark in the fuel line to the inner wall of the radius. Knowing that,we can make the first bend using the ref point on the former,insert the tube with the mark 130mm away from the inner wall of first 90,make the bend using the ref point on the former and both inner walls will be 150mm away from each other.
The bend.
You cant see the fuel line mark but its ion line with the former ref point,this is the distance you will need to heat up ,around 100mm with the bend start 2/3 its length .
This creates a very even bend.
Hold the tube around 70mm above the heat gun on high.
IMPORTANT: Keep the tube moving,rotate constantly,do not let the heat sit in any one place.
Soon the tube will not be able to hold its own weight,this is the critical moment,too long and it will create visual anomalies and start to burn.
Now i dont have pics for the next bit as i only have one pair of hands ...
When the tube starts sag,quickly transfer to the former,matching the 2 ref points up and slowly 'form' round the radiused section,dont force it,take your time. If it starts to stiffen then re heat as required.
When you are happy with your bend then let it cool naturally,when cool you can twist the fuel line straight out with no fuss.
You should be left with this
I will be adding more on the former when Magoo finds a human lackey to do the pics.
As always,heatguns are awesome but burn stuff,be careful.
EDIT: You can ditch the mark on the silicone and just put a pencil mark on the tube,it will just wipe off when done
Now,on to the prep work before insertion.
Take a file and put a small chamfer on the leading edge of the tube,this takes the sharp edge off to stop any o-ring damage
Fittings and Tube:
EK & E22 acrylic tubes come in 10mm ID and 12mm OD sizes. Both EK and Bitspower have non-compression fittings for the 10/12mm acrylic tubes.
EK and Bitspower C47 fittings are double O-Ring fittings.
Bitspower C48 fittings are skinnier and use a single O-Ring.
EK & Bitspower fittings grip really tight and you need to ensure you camber the edge of the tubes at an angle else (eg: 45deg), else you will tear your O-Rings when you put in your tubes. It helps to coat the tip of your tube in silicone grease,a thin smear will do,prior to inserting into the fittings.
You'll need to ensure your tube is seated all the way to the end and past the 2nd O-Ring.
The "seating depth" of the tube on C47 fittings is 8mm.
The "seating depth" of the tube on C48 is 4mm.
The "seating depth" of the tube on EK fittings is 9mm.
The PrimoChill acrylic tubes comes in
Inner Diameter: 3/8in.
Outer Diameter: 1/2in.
Wall Thickness: 1/16in.. This means that PrimoChill acrylic tubes and fittings are NOT compatible with EK, E22, & Bitspower tubes and fittings.
New fittings from the southern hemisphere,Rocket Science are a small enthusiast company with double o-ring fittings.
Tube OD 12mm fitment.
ITDiva has done some testing of other former materials and found that Buna N cord has nice properties for this method,it swells slightly when warm and shrinks when cold.
A nice alternative to the silicone currently used. As always,a former OD of 1mm less then the acrylic ID applies.
Monsoon have come to the game with a new mandrel set with everything you need with the basic technique shown above but with purpose built mandrels/formers and a new range of fittings with a novel locking technique.
The Monsoon hardline kit videos:
http://geno.boxgods.com/Hardline_Premium_Fittings.mp4
http://geno.boxgods.com/Hardline_Tools_Heatgun_Kit.mp4
http://geno.boxgods.com/Hardline_Tools_mandrels_and_Measure.mp4
http://geno.boxgods.com/Hardline_Tools_mandrels_and_Measure_2.mp4
http://geno.boxgods.com/Hardline_Tools_mandrels_and_Measure_3.mp4
http://geno.boxgods.com/Hardline_Cutting_Kit.mp4
This OP will be updated with a pictorial of it in use when my kit arrives.
What kind of fittings would you be using with this?
Awsome guide
Discussion starter · #3 ·
Awsome guide
With this particular tube,c47 Bitspower or any 12mm OD push fit fitting
NICE! I'm searching for a new WC build, but if it is that easy I also will use acrylic instead of "normal" tubing. When using Acrylic tube can you still use Bitspower fittings for the connection or do you guys use other kind of fittings?
Thanks alot! I miht have to use crystal tubing for my build as there are no space for anything else
Where do you buy the tubing/pipes?
Discussion starter · #7 ·
E22 has good tube
http://www.e22.biz/
Primochill has a new range out,its not on site yet but it is coming.
http://www.primochill.com/
Nice guide
Would like to add a tip. After bending, fitting and cutting to size, you can strengthen the acrylic with a process called annealing. Very simple. Switch your oven to 80C (175F), switch off fan-assisted. This is just below softening temperature. Put a sheet of grease proof paper on a flat baking tray and cook your pipe for 2 hours. Then switch off oven but don't open it yet; let it cool down naturally. This allows the acrylic to rearrange any microscopic stress fractures. It's especially important for the ends of the pipe which you are about to force into the Bitspower C47 fittings.
Oh and another thing. If you're having trouble with a too-hot airgun, then a decent hairdryer can also easily reach softening temperature.
Thank you for another useful guide...
I give this thread a B-
lol, just playing. Looks simple enough.
Awsome guide
Do you need to sand down the ends of the tube to fit into the C47? I struggle to get mine on. It's almost like it's just big enough to fit into the fittings but too big for the rubber rings.
