Howdy all, got a bit of a predicament.
Currently, I'm trying to get as much as I can out of my current rig. Basic stats:
Mobo: ASUS M4A79XTD EVO
CPU: Phenom II X4 965BE
Motherboard has a built-in mosfet heatsink. However, the heatsink still gets super hot when I'm overclocking and under load, possibly causing instability and at the very least generating extra heat for my CPU (I've got a corsair H50). As a result of my H50, I've got one fan on either side of the radiator in an exhaust configuration.
So, I'm looking to get some simple active cooling for the existing heatsink. My issues are twofold.
1. Due to bulk of radiator and accompanying fans, the MOSFETs and heatsink are right underneath one of the fans, I do have a little over an inch of clearance but there's really nowhere to mount a fan
2. I don't want to just blow hot air around up into the radiator if I can avoid it. I have an exhaust fan at the top so some would get sucked up there but I'd still like to draw as much heat away from the CPU as possible.
Short of moving the radiator and fans outside of the case to get more clearance and room to work with (not a good option for me), can anyone think of any decent and preferably cheap active cooling solution for my MOSFETs? I was initially thinking something crazy like a heat pipe on the mosfets transferring heat down to a heatsink, then having a fan blow that out the back of one of the PCI slots in my case but I haven't been able to find anything like that online. I have found aftermarket MOSFET heatsinks with attached fans but they're super expensive (like $25/pop) for what I'm trying to do.
I hope I did a good job of describing my setup, I can take pictures if necessary but not tonight as I don't have my camera.
