1 - 2 of 2 Posts
hi to all
i have a porblem in my bios setup --When I enter the bios --And go to the list of performance--Write me --- warning : (pleas clear Cmos if system no display overclocing--) and i I tried every thing --I took out the battery for ten minutes and then i put it back in the right place --- but nothing has happened - and also i clear the data C Moss and through change of location and submit your own and rewind to the right place - all this did not do nothing
not help--The warning message has been found--i tried to set setting to defulat setting-- and nothing help --
please what can i do?? i want to salles the computer--buThis problem stands in front of me and prevent me from selling--
can any body help me???
thanks for all
Does the motherboard have Jumpers?
It is usually located near that battery you mentioned. It should be 3 pins sticking out with a pastice /cover' over two. You simply move it from say position 1&2 to 2&3 for a few seconds. if you want remove the batter for a bit. replace the battery and move it back to 1&2
1 - 2 of 2 Posts
