ADATA XPG V1.0 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Description:
Cas Latency: 9 Voltage: 1.5V Timing: 9-9-9-24 Heat Spreader: Yes Features: Crafted Lines and Outstanding Heat Dissipation -Top-tier enthusiasts in all countries- from gamers, to power users, to system builders demand not only the best in heat dissipation and long term stability of DRAM, but they are increasingly looking for components that improve the overall appearance or attitude of their rigs. ADATA XPG V1.0 DRAM meets the demands of these groups, both technologically and aesthetically, and this improved heat sink is a strong step forward in this respect. With sleekly crafted lines reminiscent of the mechanical goliaths found on today's electronic battlefields, the XPG V1.0 DRAM comes in colors of red, black, and blue, grouped higher to lower according to the respective module frequencies. The Highest Standard for Stabili...
Details:
Description:
Details:
Detail | Value |
Manufacturer | ADATA |
UPC | 4713435798904 |
Condition | new |
Model Number | AX3U1600W4G9-RB |
Classification | Memory (Desktop Memory) |
