Learn how to:
  1. Add A New Item To The Database
  2. Edit A Product Description
  3. Add A New Image To A Product Page
  4. Edit Specs
  5. Edit Links
  6. Edit A Product Wiki
Add A New Product To The Database
We do our best to add a good number of products to each category, but undoubtedly we've missed a few. Thank you for your help in making the listings more complete!
  1. Navigate to the right product category. Start by heading to the review and product page center here . From there, select the appropriate product category.
  2. Click the "Add Item" Button. Once you're in your desired category, first check to make sure the product you want to add isn't there. If it's missing, look over at the top-right hand corner for the "Add Item" button.
  3. From here, you will see the Gear Finder search bar. In the search field, enter a name of the item you are looking for. You may also search based on UPC, ASIN, or ISBN to find the item you are looking for. Click "Search" when you are ready.
  4. Look through your search results to see if your desired item is there. If you see the item you're looking for, click its name to select.
  5. After you select the desired item, we may need your help to figure out where it should go. Occasionally, you may see the category selector to pick the right place for the item to go. Simply select the right category. When you have selected a final category, you will see a big green check mark. Click save and you will be directed to the new product page.
If the item you are looking for is not listed, feel free to add a product manually. Just scroll down to the bottom of the search results and click the link that says "Can't find what you're looking for? You can always add it manually."
Add An Item Manually
  1. Click the "Add Item" Button. Once you're in your desired category, first check to make sure the product you want to add isn't there. If it's missing, look over at the top-right hand corner for the "Add Item" button.
  2. After you search for the product you would like to add, if it is not presented, scroll down to the bottom of the page to begin adding a product manually. Click the link that says "Add it manually."
  3. Double check the the appropriate category is selected (it should be, but it's always good to check twice). hit "Continue to step 2".
  4. Type in the name of the Manufacturer. You will notice the display namename below will auto-populate with the manufacturer name.
  5. Add the appropriate display name. This should be a descriptive title that isn't too long. This is how the product will be named. If you look to the bottom of the page, the Verify box will auto-populate with existing products that are similar to the display name. Please check this area to make sure you're not adding a duplicate item.
  6. Add an image. This step allows you to add an image to your product page.
  7. Add a description of the product. This can always be edited later. Try to make the description as objective as possible- You can add your thoughts on the product to a review.
  8. Verify one more time that the product isn't already in the system.
  9. Hit "Continue to Step 3."
  10. Add Manufacturer. Pick an existing Manufacturer from the list, or click "No here! Add My Manufacturer". Double check to make sure another alias isn't there for your manufacturer (For example, GM is an alias of General Motors).
  11. Add some specs. It's not required, but it's helpful if you add some specs to the product page. Again, those are always editable, so feel free to come back and update stuff any time. You can add a row to the Item Details box by clicking on "New Detail". Click on each in the table to update that cell. Remove any rows that are not relevant by clicking on the X in the desired row.
  12. Add some links. Again, adding links is certainly not required, but if you know the manufacturer or product website off hand, it's helpful to add that in. Select the Type of link you are adding (e.g. Product or Manufacturer link). In the Link field, click the "Edit Link" button to enter the full URL. Make sure to add the "http://" before the URL.
  13. Finally, click the "Finished!" button. From this last page you've got a few options. You can view the page you just created, you can add another product from the same manufacturer, you can add the product to your Lists to say you own it, had it, or want it, or you can write a review.
Every product is editable by a registered member of the community. This way, you can make sure your favorite products stay up to date.
  1. Navigate to the product you would like to edit.
  2. Toward the middle of the page, you will see the Product Description tab. Above the Description, there is an "Edit" button.
  3. Click "Edit" and alter the text as you see fit. (Additionally, you can click the History link to see all previous versions of the description.)
  4. Click "Save" to save your changes.
It's always fun to look at pictures. You have the option of adding additional images.
  1. Navigate to the Product Page you would like to add images to.
  2. If the Product Page already has images, you will see a "Share Your Own Images" button underneath the Product Image thumbnails. If the Product Page has no images, you will see a button that says "No additional images for this item. Upload your own." Click one of those buttons.
  3. The Image Tool will open. From here, you have a few choices. You can browse for images on your computer by clicking the "Browse" button. You can also edit the save name of the image in the field below.
  4. Click "Add" at the bottom of the tool to upload or add the image to the page.
You can remove images or choose the primary image by clicking on any image- You'll see links at the bottom of the image viewer to do this.
Edit Details/Specs
  1. Navigate to the Product Page you would like to edit.
  2. Click on the Specs/Details tab.
  3. To add a new row, click the "New Row" button at the top. This will add a row to the spec table where you can click to see all the Specs available and enter a new value. You can use the History link to see all previous versions of this list.
  4. To edit an existing spec, simply click to the "Value" field, edit the text or select something new from a drop down, and click Save.
  5. To delete a Spec, click the X at the right of the Spec row.
Edit Links
  2. Click on the Links tab.
  3. To add a new row, click the "New Row" button at the top. This will add a row to the links table.
  4. Select the Type of link you are adding (e.g. Product or Manufacturer link). In the Link field, click the "Edit Link" button to enter the full URL. Make sure to add the "http://" before the URL. You can use the History link to see all previous versions of this list.
  5. To delete a link, click the X at the right hand side of the link.
  6. When you are finished, click "Save Changes."
Edit A Product Wiki
The Product Wiki is a great place to add additional factual information about a Product, such as "How To's," videos, links to relevant blog posts, and more.
  2. Scroll to the bottom of the page to find the Product Wiki.
  3. Click the Edit button at the right hand side.
  4. After you click edit, the Wiki Editor will open. Feel free to add images or add YouTube videos . You can edit your post similarly to a Word document, with bold, underlined, or italicized text, embedded links, bullet points, and tables.
  5. Click "Save" when you're done editing.
