1 - 15 of 15 Posts
Yes
I'm planning to add a 2nd 120mm fan to the front of my case since i have ~4 slots open. I'm looking to buy a 120mm Thermaltake Thunderblade. I was wondering what's the best way to mount it without drilling holes. Would 4 Zip-ties be strong enough to hold it in place?
Zip ties should be fine if you can pull them tight enough, if not just sit and have a look at it for a while see how you could mount it.
just buy another thermaltake I cage for like 15$
Zip-ties should work fine...
<tr>
<div>
Originally Posted by <strong>Chosen</strong>
</div>
<div style="font-style:italic">just buy another thermaltake I cage for like 15$</div>
</td>
</tr>
</table>
</div>in the NL it costs around 26 euro's... but that's just it, what is the point of 2 I cages that can hold up 6 hdd's... <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> <br />
<br />
good point <i>FaLLeNAn9eL</i>! i was thinking of the same thing cause of the looks and space of it... <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Yes
Discussion Starter #6
Thanks guys <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
I just placed an order on the 120mm Thermaltake Thunderblade at Xoxide.com<br />
about 8 bucks shipped. I'll keep you guys updated on how it goes <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
<div>Originally Posted by <strong>FaLLeNAn9eL</strong></div>
<div style="font-style:italic;">Thanks guys <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br>
I just placed an order on the 120mm Thermaltake Thunderblade at Xoxide.com<br>
about 8 bucks shipped. I'll keep you guys updated on how it goes <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"></div>
</td>
</tr></table></div>
will be following ! <img alt="" class="inlineimg" src="/images/smilies/cool.gif" style="border:0px solid;" title="Cool">
Yes
Discussion Starter #8
It finally came in today. Here are the pix<br />
<br />
<a href="http://img215.imageshack.us/my.php?image=10ae6.jpg" target="_blank"><img src="http://img215.imageshack.us/img215/2999/10ae6.th.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a><br />
<br />
Here's where I looped the zip-ties<br />
<a href="http://img84.imageshack.us/my.php?image=11pq3.jpg" target="_blank"><img src="http://img84.imageshack.us/img84/2750/11pq3.th.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a>
Good Job...looks like it lines up pretty darn good!!
I used zip ties before they officially released the icages. worked fine (Still bought icages though)<br><a href="http://assets.overclock.net.s3.amazonaws.com/3/37/3704100c_vbattach34309.jpeg"><img src="http://www.overclock.net/image/id/616208/width/525/height/525/flags/LL"></a>
i did the same as you but with a less powerful 120mm fan <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /><br />
<br />
what improvements have you seen?<br />
<br />
i saw 3C drop in CPU temp <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
you do know that coolermaster makes a gadget similar to the icage call a 4x3 rack (With a premounted 120mm fan)?
no i didnt <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /> <br />
<br />
would you be so kind as to find me some linkage?
you better be posting this mod, or i will ! <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
gonna do the same thing ! <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
<a href="http://www.coolermaster-usa.com/Products.aspx?pid=807" target="_blank">http://www.coolermaster-usa.com/Products.aspx?pid=807</a><br><br><br>
Designed for the stacker series but I have put it two other coolermaster cases (including a centurion 532 and a centurion 5)<br><a href="http://assets.overclock.net.s3.amazonaws.com/9/9e/9e12180f_vbattach34326.jpeg"><img alt="LL" src="http://cdn.overclock.net/9/9e/525x525px-LL-9e12180f_vbattach34326.jpeg" style="width:215px;height:195px;"></a>
1 - 15 of 15 Posts
