Hey community,
I recently purchased a second Crucial M4 128Gb SSD. I currently have Windows 7 installed on my first M4, along with several games. My data and my user documents (My Docs, My Pics, My Vids, etc.) are all stored on my 1Tb Seagate.
The question is: should I go ahead and put the 2 SSDs in RAID 0 for the performance boost? I don't want to have to reinstall Windows and all my games, so the only option I will consider is imagining my C: drive, installing the second card, going into RAID and then cloning the image to the RAID array.
I've heard this can be tricky. I've found a workaround here:
http://www.ocztechnologyforum.com/forum/showthread.php?72309-How-to-switch-to-RAID-0-without-reinstalling!
What do you all think? The plan for the second drive (if I don't RAID) would be to only install games and apps on it. I bought it because I'm running out of space on C:. Anyway, is it worth it? Is it risky? What do you guys recommend?
