1 - 8 of 8 Posts
i purchased the following things from another OCN member.
Swiftech MCR 220 rad
Danger Den CPX-1 pump
Swiftech MCRES Micro V1 res
Apogee GT block
I was wondering, with this setup is it possbile to cool my north and southbridges by simply adding blocks or what else would be needed?
you would need another pump. all them blocks would put in a lot of restriction. i dont think theres anypoint in w/c your sb. id just get an aftermarket heatsink/fan if i were you. and if you only did nb and cpu, not sure how much flow this pump has, but it should be able to h andle tht.
I wouldn't suggest putting any more heat in that loop! A single MCR220 is good for just a CPU.
Watercooling the SB is a waste of money (unless it's purely for the sake of l33tness), and the NB is only worth it if you will be pushing for insane clocks.
I agree. If you want to add anything to your loop, you'll need to add another rad or upgrade the MCR220 to an MCR320 or similar triple rad.
distilled water with some biocide (anti algae) such as pt nuke
1 - 8 of 8 Posts
