1 - 4 of 4 Posts
I have a friend who uses ImageReady for some stop-motion films. Instead of going out to buy after-effects, he just wants to stick to want he has. My question is, Is there any way to add one filter to multiple images at the same time? Thanks!
i dont know of one
if he has them all open he can do the filter to the first one then select each one and press Ctrl + F which will do the last filter.
quicker than opening each one at a time and applying the filer
pfft, i think you have to do them one at a time, as far as i can remember, when i was doing some of my graphics work and editing icons and things thats the way i had to do it. btw do one filter on one and then use CTRL+F it will apply the same filter to each of them.
so example if you want to get them all done with one filter, goto the first image go into the filter gallery and select the filter you want then after that all you need to do inside image ready is select the window which you want to apply the filter to and press CTRL+F saves you going back into the gallery.
hope it helps.
1 - 4 of 4 Posts
