1 - 3 of 3 Posts
I came across a pretty good deal for a hd 5850 and planning to add it to my current loop. My question is, how much will it raise my load temps?
I currently only have a single TC PA120.3 rad.
Load temps with my current setup are pretty good with the cpu (vcore @ 1.38v) peaking at around 60C in LinX and the gpu loading at 46C after 15mins of furmark stress testing.
If I can, I would like to avoid adding another rad since that will take a lot of work and at this point I am unsure of how I will mount the extra rad.
With such a small rad i would say that the load temps would increase by 10C on the Cpu. Try lowering volts with the same overclock. If that's not possible a nice 240 rad would suffice
1 - 3 of 3 Posts
