1 - 11 of 11 Posts
Sorta off/on topic, but if you're running a premix do you need any additives/kill coils or is it good to go out of the bottle?
Double post. Damn my lightning click speeds.
Premix already contains biocide and anti-corrosive. So no need to add anything.
Originally Posted by MegaHertz View Post
For those of you running Distilled Water + Kill Coil
Do you use any additional additives?
http://www.frozencpu.com/products/11744/ex-liq-154/IandH_Dead-Water_Copper_Sulfate_Biocidal_PC_Coolant_Additive_-_15_mL.html
What do you guys think about this product, should I add it to my loop? Do you use it?
Any suggestions and information would be great!
Kill coil is for inhibiting algae and the additive does the same thing. I heard that using copper sulfate causes some corrosion / leaching problem. So I would just stay with kill coil.
I know the stuff available from Mayhems, and I think Ice Dragon too, is meant to be used as is straight out of the bottle. No other additives needed. Sometimes the Mayhems are concentrates though and just require distilled to be added to get whatever mix you're going for.
Discussion Starter · #8 ·
Originally Posted by PCModderMike View Post
If you're already using kill coil, there is no need to add anything else such as that additive. I would leave it as is.
Thanks Mike, Dead Water can only help though from what I read, do you use distilled water + kill coil in your setup?
I have in the past. With my last setup though I was using Ice Dragon with a dye, no kill coil.
Nice, So you think the 2 drops of dead water I added to my distilled and kill coil setup can't hurt right? I'm hoping it can only help I don't want to have to drain and refill my loop
Sure, can't hurt.
Quoting from the description listed on the product here.
It can be used alone, or as extra insurance against growth in conjunction with silver killcoils in Pure-sil or other pre-mixed coolants.
1 - 11 of 11 Posts
