1 - 7 of 7 Posts
I recently made a thread asking users to recommend another audio editing/recording suite to me as my AA stopped working, but I found that AA was the best for me, and I can't really get used to the other ones, so I reinstalled CS5 and tried to edit a track/play a track, and this is what happened, can someone help me get this working again, I didn't install anything new, it just stopped working out of nowhere
Quarantined in the Sticks
m8 i will teach you how to use logic,... i started with AA a while back and it is not very user friendly nor is it legit.....if you got skype, i'll personally show you the basics in logic and you will be on your way brotha
he would need to buy a Mac for Logic.
use Cubase, i'll even teach you how to use it professionally. hahay!
btw i still use the old Adobe Audition 1.5. its still good for something basic. i heard new version of Audition has lots of bugs. and there is no fix for it yet.
so there's no way I can fix AA?
might give the other programs a try if that's the case.
Yeah, I'm using AA 3 right now and I don't really like it. Really wanna fix cs5
Discussion Starter · #6 ·
I think I found a fix for it. For those who have the same problem, go to : C:\\Users\\User_Name\\Appdata\\Roaming\\Adobe\\Ado be Audition\\ and delete the "4.0" folder!!
1 - 7 of 7 Posts
