1 - 2 of 2 Posts
Okay, so in Adobe Premiere, I import a video (in this case some footage of me and my friend playing GRAW on my 360). But when I try to play it in the Monitor Window under Sequence 1, the sound doesnt work, the sound works under Source, but not under sequence. The thing is it works with some videos and not with others, doesnt matter the file type, for instance AVI files, sometimes the sound works, sometimes it doesn't.<br><br>
Does anybody have any ideas, I'm sorry I can't be more clear with my explanation, just to it the other day, and have just started fiddling with it really. Any help would be great.
Yea not even in just editing, but a lot of things, i find problems with AVI, have you tried converting the ones that don't work to m-peg or something and trying that way.
1 - 2 of 2 Posts
