Advice, for my prime95 results.
1162 Views 2 Replies 3 Participants Last post by  xxicrimsonixx
Here are my results after 3 hours running 955 @ 3.5ghz (17.5multi)
It says I got an error on the 3rd core once? what does that mean?
did I fail the stability test?
also I was browsing the net during the 3hrs and installed a crysis patch.
1 - 3 of 3 Posts
Basically it means it's unstable. Lower your overclock or raise voltage values. 12 hours with no errors on all three tests is a good indication of stability. Go for 24 hours if you want to be sure.
1 - 3 of 3 Posts
