advice for voltages instead of auto
349 Views 2 Replies 3 Participants Last post by  Toonshorty
hi ,
i got a asus p5q3 and a intel q9400 + 4 gig corsair ddr3 1600 ive got this running at 3.2 with 8x400 the voltages are 1.32 for cpu and 1.5 for ddr 3 running at 1333mhz its the other volts i could do with help with as there on auto.
thank you
1 - 3 of 3 Posts
get everest m8 and that will show you what voltages you are running for most things, and then you have a starting to point to try reducing from.
http://processorfinder.intel.com
Find the max VID of your CPU there and work your way up, just make sure you don't go too high!
For example, my E5300 has a max VID of 1.365v however anything under 1.45v is safe.
1 - 3 of 3 Posts
