Advice in small(mb) benchmark please.
274 Views 7 Replies 4 Participants Last post by  CL3P20
I'm looking for a small , no more than 10mb, gpu benchmark, i have a download limit , that's the reason.
Any software that fits tha specs?
Tanks , ill post results after.
1 - 8 of 8 Posts
AtiTools
You can DL it from here in the DL section.
www.guru3d.com
It has a small bench feature that shows, 'roughly' how your rig compares to others w/ different gpu's. Its not the most widely used, but it will help you gauge performance if you are looking to OC a little.
Is it the square that indicates fps?
I was looking to something more complex....
"i hava a download limit" What do you mena with that? And yes ati tool is good. Not a really bench but you can see a cube roling and it are showing fps.
You can always run over to PCPitStop and get a fair comparison.
When i start it it says an ati card wasn't detected and most of the functions have been desactivated.And i can't overclock.
But i've seen other people with nvidia cards overclocking with ATI Tool.
Why does this happens?
becuse you are using the wrong version or the wrong program. The program I mentioned is AtiTool...not AtiTrayTool. TrayTools will only work on an Ati card I believe and has benchmark function that actually gives you a test score. AtiTool is a generic that will work for both Nvidia and Ati cards, it does not have the benchmark function but does have an atrifact tester and fps report.
1 - 8 of 8 Posts
