You are using one of the best AIO on the market and still hit high temps in certain usage scenarios.
Outside of extreme cooling solutions I would not see you drop those temps significantly during your overlock sessions.
Many undervolt these chips and get decent results.
To put things in a perspective : I have the highly unpopular 11900K cooled by Push Pull: EK-CoolStream XE 480 (Quad) | Push EK-CoolStream SE 280 (Slim Dual). Sure, I have the GPU under water as well but in extreme testing with GPU at idle and all restrictions off, I can barely keep the cpu under 90 degrees. For example all core @5.5 GHz I have 93 centigrade with it. I am running two rads with Noise Blocker fans.
