Set up # 1 wins for me, Same as my set pup now incuding GPU
On aesthetics I would say setup #2. If setup #1 was how it actually looked when it was installed you would have the tube passing in front of the GPU and that would be bad feng shui. It works in BadDad62's rig because he is watercooling the GPU.
alternative 1 - but the other direction of flow, since tho coolest radiator is on the bottom, and not on the top.
that´s how i´ve set up my rig. my cpu temps are under 60°C (cores) and the cpu is around 40-50°C @ unfair 1.38v for 4.6ghzOriginally Posted by Gleniu
Many thanks guys for ideas and feedback. It looks like both options will work, there will be small impact on performance, the rest is about aesthetics.
@Stige - good to know, I will consider this
@PinzaC55 - yes, I noticed that as well, I don't like tube in from of my GPU, but alternative means tube in frony of PSU. I will decide after I put some tubing inside and see how it looks.
@smex- that is very interesting idea, it will make rez connections a bit more complex, but something to be considered, for sure
i5 2400k @ 4.8, GTX570 , 16g Ram
Amazing tempsi5 2400k @ 4.8, GTX570 , 16g Ram
Fans are 4 Sythe GT 1850 @ 7v
Swiftech 240mm
Black Ice SR 240mm
Ambient = 24* It's 38* outside atm
CPU idle 24*
GPU idle 29*
CPU Load = 55*
GPU Load = 58*
Running Intel Burn test and Furmark for 6 hours
I'm also modding another CM690 II to fit a 420mm rad in the front and maybe a 360mm in the top
Also if using #2 i'd turn the top rad and have fittings at the front of the case and not have the GPU in the way
