1 - 5 of 5 Posts
hi guys,
I am using TRUE Black rev C, but looking to get a CoolIT Vantage ALC, and I am asking whether it is worthy, and whether the CoolIT Vantage ALC outperform TRUE black?
fyi, I am running my i7-920 @3.6Ghz, and my fullload temp is 67*C, my room temp is ~30*C, and I am planning to OC to 4.0Ghz
thanks a lot in advance.
Blue and Green Team!
If you lap the base of the TRUE black and put two high CFM fans in push pull, chances are it will be able to control high temps better than the Coolit kit however the coolit will probably idle lower and not do so well under load.
Discussion Starter #4
Actually I am using 2 Thermalright FDB 2000rpm in push/pull and they work great under load. but the Vantage ALC looks cool and very space-efficient
Originally Posted by KoolGuy View Post
Answer to all air cooling problems..
http://www.sidewindercomputers.com/de12pfexhisp.html
These arent a toy. Watch your fingers.
thank you, but it is a real thick and loud fan, and it is not available anywhere near my location
1 - 5 of 5 Posts
