1 - 9 of 9 Posts
Old dog, old tricks
Noctua. 'Nuff said.
6 U-shaped pipes (so practically 12, as I count em). Mine has 8 and a single fan and keeps 4Ghz CPU under 35C, so you can't go wrong with that Noctua.
That's a very good cooler, regarded as one of the best air coolers on the market. That thermal paste cleaner will work, another option is to use isopropyl alcohol and a paper towel which is available cheaper than that thermal paste cleaner from sites such as eBay.
EDIT - I believe the NH-D14 will fit in your case. Might be worth checking the noctua website to make sure that the cooler will clear your RAM.
Originally Posted by ronnin426850
Noctua. 'Nuff said.
Yeah that would be a great choice. As far as that cleaner goes, it should be fine, but some good old toilet paper should be ok.
Old dog, old tricks
what I do
Discussion Starter · #8 ·
I think i will order that and get a few extra case fans and see how it goes. I iwll post back when its set up. Thank you for responding quickly guys
Its been so hot playing battlefield 3
1 - 9 of 9 Posts
