So I'm new to the whole water cooling aspect of computer builds and I just wanted to get some input of the parts I'm looking at buying. I'm only doing a CPU loop so nothing to fancy I think. I feel relatively good about everything but the CPU block. I'm not on a ridiculous budget but I'm not looking to spend a crazy amount of money seen as how this is my first build. Thank you in advance for all the help!
Pump
http://www.frozencpu.com/products/2128/ex-pmp-27/Swiftech_MCP655-B_12v_Water_Pump_w_38_Conversion_Kit_317_GPH.html?tl=g30c107s1802#blank
Radiator
http://www.frozencpu.com/products/12702/ex-rad-227/Magicool_Extreme_Dual_120mm_Radiator_-_Slim_Profile_LC-RADI240.html?tl=g30c95s160
Reservoir
http://www.frozencpu.com/products/2184/ex-res-104/XSPC_525_Bay_Reservoir_-_Clear_Silver_Black.html?tl=g30c97s168
CPU Block (this is the one I'm thinking of buying but not sure about)
http://www.frozencpu.com/products/11762/ex-blc-814/MagiCool_Black_Butterfly_CPU_Liquid_Cooling_Copper_Block_-_Universal_Socket_MC-BLOCK-CPU_II.html?tl=g30c85s139
CPU Block (this is the other one I'm thinking of but only if the first one isn't a good one)
http://www.frozencpu.com/products/16395/ex-blc-1153/Alphacool_NexXxos_XP_Light_CPU_Liquid_Cooling_Block_-_Acetal_Edition_-_Intel_AMD_12153.html?tl=g30c85s139
Tubing (I think I read somewhere that 10 feet would be good because I'll have to replace some when I do maintenance but again I'm open to what you guys think I should do)
http://www.frozencpu.com/products/10691/ex-tub-663/Tygon_2475_Ultra_Chemical_Resistant_Plasticizer_Free_Tubing_-_38_ID_12_OD_-_Clear_ACG00027.html?tl=g30c99s171
Liquid (I also don't know how much of this I should buy)
http://www.frozencpu.com/products/22949/ex-liq-374/Aquacomputer_Double_Protect_Ultra_1_Anti-Corrosion_Fluid_-_Blue_-_1L_53114.html?tl=g30c337#blank
Fittings
http://www.frozencpu.com/products/8442/ex-tub-447/EK_G14_Thread_High_Flow_Barb_-_10mm_38.html
Again thank you all for the input your knowledge is much greater than mine so I appreciate anything you can pass on to me.
Pump
Radiator
Reservoir
Fittings
