1 - 6 of 6 Posts
OK...
Im looking for a new case, but Im having a hard time finding one that meets the specs I want, that doesnt have something about I dont like...so maybe someone can help.
I want to spend between $75-175 USD(give or take).
Mid-Tower or Full,(prefer mid)
Air Cooled...
At least the following fans ports, 1 x 80mm or larger side intake, 2 x 80mm or larger front intake, and at least 1 x 120mm rear exhuast(or 2 x 80mm/92mm)... top exhaust would be nice too
Aluminum construction would be nice, but not necessary.
Durability however is...I bought a rather 'tinny' $30 powmax case,...the only thing good about it is that it had all the ports I wanted and due to its cheapness, I didnt mind cutting and drilling into it to mod.
Oh ...and no plastic front panel/door thingies...if it has a door, its gotta be nice polished or brushed aluminum.
And though not necessary, removable mobo tray would be nice
Also need a new PSU, was wondering...I know while normally, the freebie, get-with-chassis PSU's are viewed as junk, however does this hold true were I to buy something like an Antec Case? I mean, I trust their PSU's by themselves...why not with a case? Ya' think they put lower quality ones in with their cases? Or are get-with-chassis PSU's ok if made by good company?
As much rep as I got to give and much appreciation for some insight.
Well I can't think of a stock case that would mee your requirements--but you could always mod one for fans--
I recently built a quiet PC with an Antec Sonata case and am using the true power that came with it--no high-end viddy card to feed so it's okay--some how I doubt the POS PSU that comes with the cases (even antec) can handle all those fans and a highend card (and multiple drives, lights, etc)
The Coolmax I am using has been fine for a water-cooled setup--2 SATA HDDs, 1 IDE HDD, 2 DVD burners, Viddy card ( on the juice), SB Audigy 2 (ditto), 3 LED fans 80, 80, 120, 2 cold cathodes--OCed and over-volted at 4 gig and running a 12VDC pump on top of all that--the rails are tight and fat and the single 3 speed 140mm fan is nice and quiet even on high.
That's not altogether true Colorsit makes very nice cases with good PSUs for less than your price range
sweet thx for the heads up...
I beg to differ I got one of the Colorsit combo cases that came with the mouse and keyboard and even cheap speakers, the case is alright but the powersupply died after about 2 months.
1 - 6 of 6 Posts
