1 - 20 of 33 Posts
Need some advice for my build i believe its pretty solid except for i havent really decided what to do for a gpu any suggestions?
CPU- http://www.microcenter.com/single_product_results.phtml?product_id=0354589
Mobo- http://www.microcenter.com/single_product_results.phtml?product_id=0384988
RAM- http://www.microcenter.com/single_product_results.phtml?product_id=0359910
Case- http://www.microcenter.com/single_product_results.phtml?product_id=0283272
Optical Drive- http://www.microcenter.com/single_product_results.phtml?product_id=0322335
PSU- http://www.microcenter.com/single_product_results.phtml?product_id=0367316
Cool Fan- http://www.microcenter.com/single_product_results.phtml?product_id=0315397
HDD- http://www.microcenter.com/single_product_results.phtml?product_id=0347227 orrrrrr
http://www.microcenter.com/single_product_results.phtml?product_id=0385098
This is what ive come up with so far tell me what you guys think... give me any suggestions....
Also can someone help me with a GPU some of you guys already did but i kinda want to pick it up tomorrow at micro center most the stuff i have linked are at Microcenter i live near the boston cambridge
what would be a good GPU for me?
should i do one or two?
If you guys think i should wait for a better one on newegg or something then let me know please smile.gif
Is this spam?
Generally posts that end in *.gif are....Why is that *.gif there??
a)wd green is 5400 rpm..get a WD blue or black
b)RAM is meh ..get this RAM http://www.newegg.com/Product/Product.aspx?Item=N82E16820147094
PSU...eh..My OCZ RMA didn't go very well.. I had to fight :
..but it should be OK
1 larger GPU is better
PC Gaming
Are you using the HDD listed as a boot drive? If so, I would recommend against using a Green drive as a boot drive. Try a WD Caviar Blue or something similar. And to echo tr4656, how much are you willing to spend on a GPU?
Discussion Starter #5
Sorry im not trying to spam just trying to look for advice...
and tr4656 i can spend up to 200 to 300 for a gpu and can you link me a psu
btw im trying to hopefully pick this all up at microcenter in boston ma tomorrow but if you think i should do newegg ill do that as well....
I would change out the Caviar Green for this one: Seagate Barracuda 500gb. Should be a bit quicker as your os drive (using the 1.5tb drive for storage).
For psu, the ZS series by OCZ are actually pretty good. At $60 after mir, that is a good deal.
Case: Skip the mir and go with this: Xigmatec Asgard. Better cable management and good airflow.
Gpu: From microcenter, this is the best deal going: Zotac 560ti $195 after $25 mir. If it was my $$, I would get the XFX 6870 from Newegg for $150 after mir - similar performance to 560ti for less $$.
Reactions: RussianHak
PC Gaming
I would recommend an MSI or ASUS 7850. Great performance for the money (usually around $250).
Also keep in mind that Microcenter will often price match products with Newegg, so if you don't want to wait for things to ship, that's always an option you should consider.
Discussion Starter #8
So you think i should get this http://www.newegg.com/Product/Product.aspx?Item=N82E16814127663 because this was on my list for gpu (just didnt want to wait)
PC Gaming
I'd personally recommend you to choose the HD 7850. Please, correct me if I'm wrong, but I think you'll be forced to run with lower settings if you choose the 550 TI.
You are correct, 7850 and the GTX 480 are equivalent to GTX 570s. I personally would go with a 7850 because it runs much cooler and is a newer gen card. The GTX 480 is just as powerful, but produces much more heat.
I agree with the MSI 7850. The 480 is now 2 generations old and is quite a power consumer (also makes a ton of heat). Get the newer card with more memory. Also, a pair of 550s may only be about equal to the 7850, but will require compatible games and possibly a larger psu. Stick with the modern card since you have the option.
Peace!!!
I would definitly change your case, if you want a case around 60$ take the cooler master cm690 II .
The best new gen gpu around 250$ is the 7850 from amd or 570 for 240$ from nvidia . ( bang for the buck )
I would recommend MSI that have good cooler and produce quality component. I know Zotac and evga does good product too with generally long term warranty.
They usually restock, but this one has a hefty rebate. HIS makes good cards. Looks to be the exact same card as the Visiontek, so not sure which one of them made it, but HIS has a 2 year warranty.
HIS H785F2G2M Radeon HD 7850 2GB $220 after $20 mir (plus $7.56 shipping). Not as hefty a cooler as the MSI, but should still do fine as the card is very power efficient. Or, just go for this one: MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB
Peace!!!
i would say going with the MSI card would good thing but if you can add a few dollars more you would get a 7870 for ~300$ which performs almost like a GTX 580
Peace!!!
1 - 20 of 33 Posts
