Well I have pretty much finally decided I want an HTPC. It is going to be air-cooled. The goal is to have it as quiet as possible and as low power as possible. I will be using an AMD x2 cpu.
Anyways, I am pretty set on getting this case and I want to paint the inside.
I will have a gigabyte 780g matx board, corsair dominator ram. So I was thinking maybe a baby or ice blue interior with a few 4" cold blue cathodes. But I just thought maybe make the inside gold and get some OCZ gold ram and some green cathodes. Just want some opinions on my ideas.
Also, what brand paint/primer would you guys recommend. The inside is aluminum so whichever paint is the best for that. I really want this case to show off its beauty. I will sleeve all the cables either blue or green(whichever color scheme I go with)
