Advice on this rig?
257 Views 5 Replies 4 Participants Last post by  ele1122
Hey guys. What do you think about this set up:
Mobo: http://www.newegg.com/Product/Produc...82E16813131366
RAM: http://www.newegg.com/Product/Produc...82E16820231281
CPU:http://www.newegg.com/Product/Produc...82E16819103674
If you have better ideas, feel free to tell me.
1 - 6 of 6 Posts
For a start get this RAM
http://www.newegg.com/Product/Produc...-279-_-Product
You will never get the ram you chose to run at 2000Mhz
and if you can stretch get this CPU as it is a much better overclocker
http://www.newegg.com/Product/Produc...-727-_-Product
Also I ran the Ripjaws I linked on my GD70 with my 720BE with no probs.
Ok, thanks. So far it looks like that's in my budget.
Would the same cooler I used on an Intel CPU work for the AMD?
No you would have to use a different cooler from Intel to AMD. Though some aftermarket coolers come with adapters to accomodate both.
Ugh... I guess I'll have to settle with the stock cooler then...
Thanks for the help guys.
1 - 6 of 6 Posts
