1 - 2 of 2 Posts
Hey I have decided to build my first pc and I wanted help deciding how to maximize my budget. My total budget not including os is approx. $700. I will be using the computer for gaming and After Effects among other things.
I dont know if it matters but i'm using a HDTV for a monitor and I don't need a DVD drive. I was planning to use this case http://www.newegg.com/Product/Product.aspx?Item=N82E16811129097 but i can change it if need be. Thanks for any help in advance.
what exactly are you asking?
for us to tell you what you should buy?
just browse newegg. and work it down.
get an idea and then come back and ask for input?
perhaps somone will be kind enough to help you tho
i just figured that would be the best way for you and everyone
1 - 2 of 2 Posts
