Originally Posted by thedog123123
i was wondering what type of fan/heatsink i should get for my AMD athlon xp 2600+ (runs at 1.92) so i get the maxium cooling for overclocking. (also if possible if someone can tell me what I should overclock my cpu without damaging it.
If you're on a budget get a Thermaltake Volcano 12 (about 30 dollars). If money is not an issue then get a Thermalright Si-97 with a 92mm tornado (about the best air cooling avaliable for socket A ATM)
The only way to really know what's safe for your CPU is to overclock little by little, dont take big jumps in voltage and keep an eye on your temperatures everytime you make changes. Also set a shutdown temp of about 60C so if something bad should happen the PC would just shut down and not damage the CPU.
