1 - 5 of 5 Posts
Retired but not dead!
Originally Posted by jop14 View Post
I might go for this one instead of the Kingston, i think it got better speed and its cheaper. 129$ with rebate
Do you know if they are good?
http://ncix.com/products/index.php?sku=64080&promoid=1130
and do i need to buy sata3 cable or the blue cable that came with my gigabyte board is ok?
That's a 2nd tier Sandforce 2281 drive. The m4 is going to be faster and more reliable for $25 more.
And no, you should be just fine with the Sata cable that came with the board.
A good quality Sata 3gb/s cable can carry the 6gb/s signal as well.
1 - 5 of 5 Posts
