1 - 8 of 8 Posts
hi,
i have been using the Creative Soundblaster AE5 since last year and iam slowly getting fed up with their software (keeps forgetting settings after every reboot, software pretty slow on high-end PCs, microphone is total garbage).
iam using DT990 250ohm headphones, which i want to keep (i like the sound of it alot).
iam thinking about to buy the Mayflower ARC or O2/ODAC, i'd prefer the ARC because of the Bass Boost and Mic-In.
how do those external DACs compare to the AE-5 in sound quality? better?
should i rather get a schiit stack (magni/modi)?
does the windows driver have a "Bass Boost" feature on such external DACs? (i might need a small +5db boost)
Overclock Failed...
Generally, sound cards sound better than onboard and external DACs sound better than sound cards.
But that's like saying red cars are better than blue cars - it depends.
Music? Movies? Gaming? Stereo? Multichannel?
As for base, Equalizer APO.
Overclocking Enthusiast
Bass boost does work on external DAC's. I have the magni/modi combo. I think you would be better off with a DAC with that headset you are using. I normally recommend a DAC with it's own power source.
I dunno what I'm doing.
I have zero experience with Mayflower or their ARC, but I've used the ODAC/O2 combo before and it's a pretty decent solid-state amp. The ARC seems like an ODAC/O2 with an added mic input, so probably a good choice as a direct soundcard replacement. Not sure if it'll have the oomph to push those DT990s properly (if it is an O2 amp, it should be fine), but that's not a huge concern since it has RCA outputs you can connect an external amp to if need be. Which you should. A tube amp to be specific. Tubes are love, tubes are life.
Discussion Starter #5 (Edited)
APO equalizer seems great, i already tested that on my AE5 :)
as for my usage:
iam a gamer but i have music on 24/7 and iam very keen on decent music quality.
stereo mode only for me without weird sound effects.
(i basically just need a small Bass Boost, thats really all i need sometimes).
right now, i would like to buy the magni and modi-uber from schiit. (the magni beeing more powerful than the odacs amp)
the normal schiit modi is powered via _USB_, i think that makes it worse?
iam not sure regarding a tube amp (Schiit Vali), from what i understand, it makes the sound less bright.
Discussion Starter #7 (Edited)
a small update:
i have ordered Schiit Magni3 and Modi2U last week and the setup is already running since yesterday.
very impressed so far.
it does get a bit louder than the AE-5 on max. gain, but the soundstage is better on the schiit setup.
also the bass has more punch with the schiit setup, i had to use EQ on the AE-5 to have decent bass. (DT990 250ohm)
iam still comparing it to the ae-5 and switch my headphones between those two audio devices, but also the treble is different (schiit = brighter/clearer sounding?).
equalizer & other effects are disabled, running everything stereo atm.
APO Equalizer works without any problems too, alternatively theres the windows integrated EQ on the driver (install Schiit drivers for that).
Overclock Failed...
We're glad to see you're happy!
1 - 8 of 8 Posts
