AeroCool MicroATX Cases DS-Cube Black
Description:
AeroCool Designed, DS-Cube Super Silent MicroATX case solidly constructed chassis with 0.8mm SGCC to block out all noise. This case supports all mini ITX and Micro ATX motherboards, and it also supports standard ATX power supply with up to 160mm depth recommended. Leather coated exterior with smooth surface finishing. Removable top panel for easy access to motherboard and act as a dust filter also. Removable ODD and FDD racks for ease of installing water cooling system. Pre-drilled holes designed for cable management and water cooling pipe installation. Support 1 x 5.25" external, 1 x 3.5" external, 2 x 3.5" and 2 x 2.5" internal. Support high-end graphic card up to 320mm. Supports 2 x USB2.0, 2 x USB 3.0, and audio & Mic. Include 1 x 200mm front fan and a 120mm rear fan. Case Dimensions: 265mm(W) x 411.3mm(H) x 381mm(D). Drive Bays: 1 x 5.25" external ; 1 x 3.5" External; 2 x 3.5" and 2 x 2.5" internal. 4 PCI Expansion Slots. Customer Service: Supportataerocool.us or call 510-661-9948. RMA Service: RMAataerocool.us or call 510-661-9948.
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | AeroCool |
EAN | 0841269021968 |
Feature | Super Silent solid built chassis Micro ATX cube case with tools installation and water cooling ready Include 2 x USB2.0 and 2 x USB3.0 and Audio and Mic ports Support 1 x 5.25" external and 1 x 3.5" external bay and 2 x 3.5" and 2 x 2.5" HDD internal bays Include 1 x 200mm and 1 x 120mm fans Support long VGA up to 320 and CPU heat sink height up to 190mm Leather coating with easy removable top panel design for easy access to motherboard during installation Support Standard ATX Power Supply with depth up to 160mm recommended |
Label | AeroCool |
Manufacturer | AeroCool |
Model | DS-Cube |
MPN | EN52254 |
Publisher | AeroCool |
Studio | AeroCool |
Title | AeroCool MicroATX Cases DS-Cube Black |
UPC | 841269021968 |
Warranty | 1 year parts and labor |
Color | Black |
CatalogNumberList - CatalogNumberListElement | EN52254 |
Item Height | 17.5 inches |
Item Length | 13 inches |
Item Width | 19 inches |
Package Height | 13.1 inches |
Package Length | 19.4 inches |
Package Weight | 19.25 pounds |
Package Width | 17.9 inches |
PackageQuantity | 1 |
PartNumber | EN52254 |
ProductGroup | Personal Computer |
ProductTypeName | SYSTEM_CABINET |
UPCList - UPCListElement | 841269021968 |
Item Weight | 18.8 pounds |
