1 - 3 of 3 Posts
When i come back to my computer I will try to open firefox and nothing will happen, then I try Chrome and nothing will load. so I try IE and I get an appcrash. None of my programs will open at all. I can't even open Paint to post a screenshot. All of my programs will crash until I reboot which I can't even do through windows when this happens! After i reboot everything is fine until I let it idle for an hour or more. The computer does not go to sleep or hibernate and I have all power saving features turned off. I can't figure out what causes this only after the computer has been idling.
I am in Event viewer right now and although it says there are over 2,000 application events, I can't see ANY of them. I have event logging turned on too
Discussion Starter · #2 ·
Here are my event logs from the programs I try to open that crash:
Faulting application name: iexplore.exe, version: 8.0.7600.16385, time stamp: 0x4a5bc69e
Faulting module name: iertutil.dll, version: 8.0.7600.16385, time stamp: 0x4a5bda0c
Exception code: 0xc0000005
Fault offset: 0x0016112c
Faulting process id: 0x1056c
Faulting application start time: 0x01cac30202ac17be
Faulting application path: C:\\Program Files (x86)\\Internet Explorer\\iexplore.exe
Faulting module path: C:\\Windows\\syswow64\\iertutil.dll
Report Id: 40d772ab-2ef5-11df-b1b9-00508db77064
Faulting application name: GameBooster.exe, version: 1.3.1.83, time stamp: 0x4b623ade
Faulting module name: KERNELBASE.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdbdf
Exception code: 0x0eedfade
Fault offset: 0x0000b727
Faulting process id: 0x1291c
Faulting application start time: 0x01cac3021ccd85a4
Faulting application path: C:\\Program Files (x86)\\IObit\\Game Booster\\GameBooster.exe
Faulting module path: C:\\Windows\\syswow64\\KERNELBASE.dll
Report Id: 5b22bfdd-2ef5-11df-b1b9-00508db77064
Faulting application name: Foxit Reader.exe, version: 3.2.0.303, time stamp: 0x4b8e15b9
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Fault offset: 0x74e4c9f1
Faulting process id: 0x12a1c
Faulting application start time: 0x01cac302289d904d
Faulting application path: C:\\Program Files (x86)\\Foxit Software\\Foxit Reader\\Foxit Reader.exe
Faulting module path: unknown
Report Id: 66ac28dd-2ef5-11df-b1b9-00508db77064
Faulting application name: IObit SmartDefrag.exe, version: 1.4.0.0, time stamp: 0x4b443b5e
Faulting process id: 0x12b0c
Faulting application start time: 0x01cac3023d95b4fe
Faulting application path: C:\\Program Files (x86)\\IObit\\IObit SmartDefrag\\IObit SmartDefrag.exe
Report Id: 7b992087-2ef5-11df-b1b9-00508db77064
Faulting application name: ContextMenu.exe, version: 0.0.0.0, time stamp: 0x2a425e19
Faulting process id: 0xf3c0
Faulting application start time: 0x01cac3024b580b22
Faulting application path: C:\\Program Files (x86)\\IObit\\Advanced SystemCare 3\\ContextMenu.exe
Report Id: 894de74b-2ef5-11df-b1b9-00508db77064
volmgr: Crash dump initialization failed!
Log Name: System
Source: volmgr
Date: 3/13/2010 6:12:39 PM
Event ID: 46
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Owner-PC
Description:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="volmgr" />
<EventID Qualifiers="49156">46</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-03-13T23:12:39.000000000Z" />
<EventRecordID>8801</EventRecordID>
<Channel>System</Channel>
<Computer>Owner-PC</Computer>
<Security />
</System>
<EventData>
\\Device\\HarddiskVolume1
<Binary>0000000001000000000000002E0004C00110000001 0000C000000000000000000000000000000000</Binary>
</EventData>
</Event>
1 - 3 of 3 Posts
