Hello,
5 days ago, I wanted to check/test my old GPU for a last time for functionality, before finally selling it - at first, I wanted to do that immediately after procuring my (then) new GPU almost 3 years ago, but then decided to preserve it as a backup solution for the case my (then) new GPU goes defunct or I decide to sell it. So it lay in my room untouched for about 2 years straight. Now, I have yet again a new GPU (a RTX 3080 Ti) which I didn't even unbox yet and so, I began to disassemble my current GPU (a Turing-based Nvidia-GPU), but BEFORE inserting the 3080 Ti I wanted to do a final checkup of the old GPU laying in my room since years like I mentioned at the beginning of this posting...
This is how the procedure went on:
Result: The computer immediately turns on (all fans start spinning: CPU fans, chassis fans, PSU fans) and within a second completely turns off again.
Now, I'm familiar to this phenomenon of multiple On's & Off's automatically in a row (or loop, if OC isn't stable) before finally successfully POSTing, after the motherboard was deprived of power for a longer time, but THIS TIME there were no consecutive/repeated Turn-Ons in a row - and not even a loop! The system just turns off within a second of pressing either the chassis power button or the onboard power button - and that's it! I would have to press the button again myself to initiate another Turn-On and again within a second, it turns off completely without further activity!
I need to mention that the motherboard itself appears to be fine, though - the RGB lighting flows through the board as usual and the onboard power button is glowing white as normal...
I have tried various solutions to fix this:
(for each solution, I performed the first 3 steps and eventually the last 3 steps of the above listed procedure)
None of them worked and slow, but surely I'm starting to become desperate
Please help!
T.S.O.M.
- Power off Computer by shutting down Windows
- Turn off PSU switch (PSU cable still connected to PSU)
- Turn off power source switch (PSU cable still connected to power outlet of power source)
- Discharge myself by touching the radiator of a heater
- Lay the computer case flat
- Screw off GPU screwdriver
- Remove power supply cables from my currently used GPU
- Release GPU by pressing the PCIE lock
- Remove current GPU and place it on a safe spot in my room
- Insert old GPU (that laid in my room for years)
- Connect PSU power supply cables to GPU
- Screw up GPU screwdriver
- Connect GPU to Monitor
- Power on power source switch
- Power on PSU switch
- Power on Computer by pressing chassis power button
- removing old GPU and re-inserting my currently used GPU -> problem still persists!
- powering up with NO GPU at all (both PCI-E x16/x8 slots empty/free), monitor connected to integrated GPU on MB backpanel via DisplayPort -> problem still persists!
- checking cables and connections on motherboard, PSU and chassis
- pressing and holding the "Clear CMOS" button on motherboard backpanel for 10 seconds and then Re-Try
- removing CMOS battery for over 5 minutes and re-insert, then Re-Try
- pressing and holding the chassis power button and onboard power button each one for 30 seconds to remove any residual current
- testing PSU for functionality by unplugging all cables and then plugging the 10+18 pin motherboard power cable to PSU with the other end of the cable attached to Seasonic's PSU Tester device. -> PSU has no issues.
Please help!
T.S.O.M.
