This is for GPU custom loop only ( RX 6800 ). So the CPU block is not included. In the future I might add a second radiator (240mm and 25mm max, like some Alphacool ST25) and "maybe" include the CPU into the loop (but the CPU is just fine at the moment). My case is an Evolv ITX. I don't overclock.
I wanted to get an Alphacool DIY kit (much cheaper and less issues with availability), but the ones with good pumps that I found, all come with an 45mm thick radiator that will cause me issues in my small rig (and will make me remove the CPU cooler).
So I finally managed to get stock everywhere, in two different shops, except for the water block which will make me wait.
Notes:
1) I'm getting a D5 pump because I heard good stuff about it. But I'll try to run the pump with speed "2"/5 to save power. (I understand the power consumption is lower at low speed). I understand the Alphacool Reservoir (Eisstation VPP) includes the O-Ring and supports any D5.
2) I'm getting the X-Flow version of the radiator, a bit larger, but just because it has a regular restriction (compared to the non-xflow version that has a huge restriction).
List (sorry for not putting everything in English. Some pages only let you use the local language):
Somebody could tell me if I am missing something and I'm not messing up anything? (Except for the 2 fans, I'll get those later, maybe Noctua Redux 120mm 1200RPM PWM).
My only fear is that everything will come to me and I am missing parts or I may have chosen something wrong. Mixing brands, etc.
I might add one additional meter of "AlphaTube". But I only need 3 tubes: from Rad to GPU, from GPU to Reservoir and Reservoir to the Xflow Radiator.
Apologies for the inconvenience!
Update: Had to replace the Eisblock GPU block because there is no availability anymore and no ETA for this. I went with a more expensive EKWB gpu block that doesn't include the backplate so I had to buy separately:
I also added a funnel to Aquatuning order as recommended
Notes:
