1 - 17 of 17 Posts
Moved all the sliders in Afterburner as high as they could go
System:
Xeon X3440 - 3.9GHz
2x2gb DDR3 1640 8-7-7-21-1T
MSI GTX 470 915/1830/2190
mmmmmmmm
Max temp was 50C.
Reactions: chatch15117
Originally Posted by C-zom
That is a ridiculously high voltage for 3.9GHz bro. Other than that, nice job on the card.
I'm sure his watercooling keeps it under control
Discussion Starter · #6 ·
Well that is before Vdroop. When under stress it goes down to 1.39v.
Discussion Starter · #8 ·
Originally Posted by cdolphin
Those are amazing clocks. Can you elaborate as to cooling?
I think you can edit the .cfg and change the limits for after burner? Please do
I am using an MCW60 water block on the video card. Rest of the loop goes as follows.
DD CPX-1 Pump
Feser Quad Rad
GTZ CPU Block
MCW60 GPU Block
Micro Res
And I have tried editing the file. I think the GPU BIOS won't allow more than 1.087v.
Reactions: tipsycoma
Discussion Starter · #11 ·
Originally Posted by 9KRacing View Post
Flash your BIOS. Here.
Thanks! Never flashed an NV card before. Need guide plz. Too lazy for google.
Originally Posted by chatch15117 View Post
you and your damn water cooling
+2
It is sad when you get to the limits of a card which are hindering performance gains.
Check the link in my sig for a BIOS guide. Try maxing out NVIDIA Inspector shader and memory sliders
. 2GHz core
Discussion Starter · #14 ·
. 2GHz core
lol Thanks for the guide.
Good thing I'm under water. Loading at 64C at 1.21v
Discussion Starter · #16 ·
I would like to see benches at 940 core..... that's scary fast.
Yeah. I got 985MHz stable with 1.21v. But, having some issues with the card's over-current protection. Once I get past it I will post up 985MHz results.
WE WANT RESULTS!!!
1 - 17 of 17 Posts
