Aftika/Hakuna Matata issue
888 Views 11 Replies 3 Participants Last post by  /Ben
So, I have Hakuna Matata for a while now and I love every bit of it. I have the Korean PAL version (English disc and game).
But I have a few questions about the game.
1) I looked on someone's profile last week, and I noticed she had trophies with Afrika (NOTE: I have Hakuna Matata). Would I have to get Afrika for the trophies? I love trophies so I DO want those trophies.
2) If I do get Afrika, it will have to be the NTSC American version. Will this give any problems since I play in a PAL region?
3) Last but not least, how many versions are there? Just two? Korean PAL and American NTSC versions?
1 - 12 of 12 Posts
1: If "Hakuna Matata" doesnt give you Trophies. You'll need to get Afrika
2: Games, I'm pretty sure. Are only region coded for DLC. Don't quote me on that. So get either
3: Theres many, many versions of all games. So. No.
Most of these are just based off my common knowledge with my PS3
Ok thanks for the answers Noob. What are the differences between NTSC and PAL? Something with the resolution right?
Thanks again.
By looking at the diagram alone, the colors say enough... Bigger IS better in this case. NTSC has almost only worst ratings in the diagram. PAL only has the best ratings. Choice made. Thanks. REP+ WannaBeNoob. I think I'm going to have to look for Afrika in English and PAL. Or if that doesn't exist, Afrika in PAL might do.
Which countries have English games outside of Europe in PAL?
almost all games or all settings have language option settings INgame
No, I mean, the casing of the games. Not the games themselves.
sad to say, but you'd have to just deal with it, or import a copy of the game just for the case.
Originally Posted by /Ben
Thanks again.
The diagram doesn't say it all because NTSC has a higher framerate. With movies it doesn't matter much because they can blur the frames to make you think it's smooth, but with games you'll notice a difference (25FPS vs 30FPS).
As long as it's smooth I'm Ok with it. I'm not a FPS junkie like alot of others here. I don't see the problem between 40 and 100 FPS... It's all about the resolution imo.
No I know, higher FPS isn't very noticable (because you're really going from 40 to 60 because of the monitor). But 25 to 30 can make a big difference.
Yeah I agree on that. I used to play WoW @ ~30FPS. It was very smooth. Untill it dropped below 25...
1 - 12 of 12 Posts
