1 - 10 of 10 Posts
This is a post i made to another forum at anandtech, would appreciate any opinions you guys here would have and maybe a little guidance... <br />
<br />
Hey yoxxy great post man very helpful.Just have a few uneducated questions before i delve into your methods. Based on the components i have which plan should i follow . Would it still be the Mainstream Overclocked Gamer or would you suggest another plan of attack. Secondly would you recommend bothering with replacing the stock CPU cooler with the Gigabyte fan or leaving it seeing as i have a 120mm fan behind it and a 200mm fan above it connected by default to the case. And lastly do you think i could probably push this one a bit harder with the memory thats in there. <br />
<br />
Thanks in advance. And HI to all the guys and gals here it seems like a very informative site. Feel free to chime in with any opinions you may have on my particular system, bearing in mind I have no experience whatsoever at OCing . <br />
<br />
Ahh yeah it goes without saying that i only just read this post otherwise i might have bought a closer machine to yoxxy's specs. <br />
<br />
-------------------------<br />
Asus P5B Deluxe Wifi....E6600....OCZ 4-5-4 PC2-8000 Platinum XTC Extreme 2GB DDR2-1000Mhz....BFG 7950GT....WD RaptorX 150gb....Antec 900 Case....Silverstone 800W....Chimei 221D Monitor....Gigabyte Geforce(not installed yet, stock fan in place, but would like to see how far I can push it without it as my case is like a windy city)
Discussion Starter #2
memset screenshot<br />
<br />
Fear Screenshot:FearFlatout. Everything on max/ bar Computer(high) and GraphicsCard(high). No overclocking yet.Don't know if this is good or bad, but it plays well.<br><a href="http://assets.overclock.net.s3.amazonaws.com/0/0a/0a9a7081_vbattach34033.jpeg"><img src="http://www.overclock.net/image/id/616428/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/2/23/23dca804_vbattach34034.jpeg"><img src="http://www.overclock.net/image/id/616427/width/525/height/525/flags/LL"></a>
Cool. Nice post on the other forum. Are we meant to be helping with something because i dont understand the point to this thread...<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>The Fury</strong>
</div>
<div style="font-style:italic">Cool. Nice post on the other forum. Are we meant to be helping with something because i dont understand the point to this thread...<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /></div>
</td>
</tr>
</table>
</div><br />
Yeah thanks man. <br />
Basically what i was asking for was help on how to overclock my system, but now i gotta go to bed, got work in 6 hours. Any pointers would be good, and ill check in tommorrow.<br />
Cheers
Would be best if you bought a new cooling fan, Scyth Infinty, Thermaltake Big Typhoon, Tuniq Tower. Typical Settings for your setup and hitting 3.6 ghz would be.<br><br>
# vCore: 1.525 (Vdroop to 1.45 under full load)(3.6 ghz)<br>
# vFSB: 1.4<br>
# vNB: 1.4<br>
# vMem: 2.25<br>
# Configured FSB: 400<br>
# Memory Ratio should be 4:5 or DDR2-1000<br>
# Configured Ratio: 9<br>
# Configured Memory Timings: 4-4-4-4 (Configured under Chipset)<br>
# C1E and SpeedStep off, Locked PCI Express Frequency locked at 100, PCI Sync Mode at 33.33.<br><br>
The ram you have is pretty great, works very well with lower timings than it says. It is D9GKX which is still the best DDR2 you can buy.<br><br>
That VCore may end up being kind of high but you can lower it when you know you are stable. Gives you a good place to start though. But I would definetly buy a new cpu fan before you do that <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">.<br><br>
Another way is to configure the ratio as 8 keep the other settings the same and leave vCore @ 1.3815 for now. That would give you 3.2 ghz and would be more than stable with the stock cooler.<br><br>
Cheers.
<div>Originally Posted by <strong>Yoxxy</strong></div>
<div style="font-style:italic;">Would be best if you bought a new cooling fan, Scyth Infinty, Thermaltake Big Typhoon, Tuniq Tower. Typical Settings for your setup and hitting 3.6 ghz would be.<br><br>
# vFSB: 1.4<br>
# vNB: 1.4<br>
# vMem: 2.25<br>
Cheers.</div>
</td>
</tr></table></div>
<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"> Yoxxy. I agree that the vcore may be too high.<br><br>
Try getting stable with less voltage, no need to pu undue thermal-stress on the CPU until you have to. And if it hasn't been said - aftermaket cooler is hghly recommended.<br><br>
Your system looks Grrrrreeeat <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Discussion Starter #9
# vFSB: 1.4<br>
# vNB: 1.4<br>
# vMem: 2.25<br>
Cheers.</div>
</td>
</tr></table></div>
Thanks yoxxi you the man. Will try these settings when i get home from work. Thanks again.
Discussion Starter #10
<div>Originally Posted by <strong>Yoxxy</strong> <a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1376144#post1376144"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
# vFSB: 1.4<br>
# vNB: 1.4<br>
# vMem: 2.25<br>
Cheers.</div>
</td>
</tr></table></div>
Unfortunately these settings have'nt worked for me whatsoever I have'nt even gotten a boot up just a black screen, which required a shutdown and a power off from the wall socket, then on restart choose default setting(F2).<br>
Also a strange thing I noticed is that Hyper Threading and Intel SpeedStep are not even listed as options in Bios, and yes I looked at my manual to see where they reside. Another thing is that I am not able to configure the individual ram timings in Bios either. I am a little confused! Has my Bios been corrupted or is there something i am missing. I would think it strange the Bios being corrupted as everything works fine at default setting and the revision is 0711.<br><br>
Thanks in advance
1 - 10 of 10 Posts
