Again Do u thnk my temps are fine ?(WC)
404 Views 8 Replies 2 Participants Last post by  Traeumt
Vcore:1.330 core speed:4200
Stress test:Linx20mins
Max temp reached:59
Thank you for your suggestions
CPu block:hk3.0
other components : not as good as block
1 - 9 of 9 Posts
for a quad core 60C for 1.33v would be good, but for a dual... not so much. But those are safe temps, and no other programs or games (except stress-test) will be able to work the cpu that hard so daily use will be even less.
(just for comparison, the oc in my sig was at 55C)
4 hours of prime can only get me max temp 47 but linx ...
and did you used Linx while testing your stability ?
Is that small ffts prime? because large and blend focus more on mobo and ram stressing, and the cpu isn't being pushed as hard as in small.
The 55C i was talking about earlier was in the 11th hour of a custom loop of ffts. I've found that (most of the time) the smaller fft size, the hotter the cpu runs. And i had forgotten to open my window or door so the ambient temp in the room was 77F
But to answer your question, yes, linx can run hotter than prime, which would partially explain your high temps. But what rad, pump, and size tubing are you using?
on small ffts it goes max like 50
not a custom small ffts but small is small right ?
8k ffts like 8 hours didnt went over 50 so the linx is devil !
thank you Linky
thank you Linky
np, happy to help. Well at least we know linx is good for another 9-10 degrees over prime!
Yeahh and thats not good i want to stick with Prime Lol
well ideally the hotter the program can make your cpu the better, because that means its that much closer to being truly 100% stressed. But to each his own
Also, do you really live in Turkey? You speak very good english
Yeah i really live in Turkey and thx
OCN made me speak better
1 - 9 of 9 Posts
