How do i up my AGP voltage? I can't find a setting for it in my BIOS.
Originally Posted by LifIsPeachy02 How do i up my AGP voltage? I can't find a setting for it in my BIOS. |
Originally Posted by Leprachuan you have to do a volt mod which isnt easy..im pretty sure you can't do it through bios or and software you have to physically mod it. |
Originally Posted by Ket overvolting the AGP bus generally isnt needed although it has been known to prevent "stutter" through the card receiving bad signals at default AGP voltage, do not raise your AGP voltage above 1.7v. for any VC info you need try checking out my guide ![]() |
Originally Posted by Ket in your bios somewhere there will be an option saying something along the lines of "AGP voltage" the setting you should see next to it is 1.55v, raise this to 1.6v and that will supply a much better signal to your VC ![]() |
Originally Posted by Ket hmm......odd, if its really not there try updating your bios. |
Originally Posted by LifIsPeachy02 I will try that. Can i make a CD-R bootable for this instead of a floppy i don't have a floppy drive?? |
