Welp... this is what it looks like now. I was taking down my rig for spring cleaning, but before I did that I decided to drop by and NCIX and purchase an 8-pin EPS extender. Now that my 8-pin could be tucked away behind my motherboard area, I decided to give the entire case a facelift. This also shows some of my case mods including the front fan ziptied to the 5.25" drive bays, the huge black wind tunnel (made of cardboard and electrical tape. Ghetto ftw
I'm still planning numerous mods including a side panel window, some sound dampening material and I might even paint the case black. However, since I'm a 14-year-old that's very short on time and budget, I have no idea if neither of those can even happen
(Also, in case you're wodnering, I moved those last two fan plugs out of sight after taking this pic
Along with a clean, dust-free case and that big wind tunnel over the back of my video card, my entire system looks quite sexy IMO
COMPARISON: After (some) cable management in January [link]
COMPARISON: Before any cable management [link]. Ugly, right?
Some more pictures:
My Dark Knight with push-pull, looking clean and smexy
Just another shot of the thing. Because the lighting looked so natural, I had to post it
Behind the motherboard. Not-so-smexy now, eh?
There was a problem with the top part of the front panel not latching in properly. In order to fix it, I had to literally put the force of my entire body onto that front panel and push it down.... and then it locked into place. Yes.......I used my body
And the rest can be viewed here
-xd
