AHAHHAHAH Overkill Much? 750W for my system
662 Views 17 Replies 11 Participants Last post by  arekieh
Lol Look at my specs..... i had dual 4870's and stopped gaming
. SHould i just sell it and downgrade? I want a high quality PSU and got this for really cheap. What else is there out there thats better? Maybe something modular 620HX?
1 - 18 of 18 Posts
If you're going to stick with onboard then even that 620HX is overkill. Perhaps the 520HX if you want a high quality modular unit?
I'd get a cheap antec 500W PSU...
Originally Posted by MNiceGuy
If you're going to stick with onboard then even that HX620 is overkill. Perhaps the HX520 if you want a high quality modular unit?
Absolutely agreed. The HX520 is a fabulous lower wattage PSU. Although it can run a couple of 8800GT's SLI'd with ease, if you ever decided to get back into gaming
youd prolly be able to get away with a good ~400watt psu if you go with onboard
Dude, what are you going to get for that PSU? Half of what you paid for it? Just keep it, and keep overclocking. No sense AT ALL in getting rid of it.
Unless you REALLY needed the money...which I doubt.
If you're willing to toss modularity you could even step down to Corsair's 400-450 watt models. Antec makes a good low-watt PSU as well as the Thermaltake 430W. I've used the latter a couple times for budget builds and never heard back with any problems.
EDIT: After reading the above post I looked at your sig rig. You have a freakin' PC P&P already! I don't know why but I assumed you were ditching a low-quality, high-power PSU for vice-versa. I mean it's a PC P&C! Silly OP
don't bother downgrading. it's better to have more than enough power and not use it, than too little power and not have it.
Unless you really need the $40 or $50 you'd get out of it... There is no point.
Even the Corsair 450 is going to run $70 which is probably close enough to what you'd get for the Silencer that it would be pointless. The only reason I could convince myself to do it was if I wanted modularity (going to cost you out of pocket at that point). That PC P&C has big, stiff cables.
dude, what are you going to get for that psu? Half of what you paid for it? Just keep it, and keep overclocking. No sense at all in getting rid of it.
Unless you really needed the money...which i doubt.
+1
I got it for $90cad (around ~70 usd). So ya it would basically be a straight trade for something crappier?
Thats what i was thinking, but i thought maybe i was going a bit crazy lol.
Just checking to make sure im not making a bad decision. I think im just gonna keep it. never know maybe ill randomly get a 4870x2
Yeah just keep it. Heck I dont game much I still like having the hardware for once every few weeks when I do game lol.
Well i was gonna keep my gpu's then i wanted a Silverstone Raven.
had to sell some stuff
Dude you have a great power supply just keep it just in case you decide to up-grade and you only use as many watts as your rig needs like at idol i pull 110w from the wall and wile gaming i pull about 165watts
ya, guess ill keep it then. Thansk guys
Trade me for my 620HX
All you gotta do is pay shipping!
lol no thanks
1 - 18 of 18 Posts
