I am looking at some of the 2.5" enclocures for my 160Gb laptop SATA HDD I have extra after upgrading to a 7200 spin HDD. After looking around, I found a nice enclusure that also comes with a 3.5"/.5.25" desktop adapter mount. So the question is, with SATA set to RAID (I have RAID 0), are the SATA ports hot swappable?
Here is the enclosure in question:
http://www.newegg.com/Product/Produc...82E16817392011
This is all I can find on it ATM:
http://www.raid-data-recovery.net/ra...-swapping.html
But will it interfere with my RAID 0?
The hot swapping is done in almost all the available types of the RAID. The most of the available types of the RAID; support the concept of the hot swapping. The hot swapping can be even implemented in the IDE RAID, SCSI RAID, and also the SATA RAID. The concept of the hot swapping seems to be simple but at the time of the implementation is a bit difficult. The hot swapping can be even more complex process in the implementation of the different nested levels of the RAID. As it is considered that there are different levels in the RAID. The RAID levels may include the Single RAID Levels and the Multiple RAID Levels or also known as the nested RAID Levels. |
