Disclaimer: This thread is not an attempt to convince people that one is better than the other. These are my results and conclusions which I wanted to share so we could discuss and hopefully learn something
Test bench:
Intel 3770K @ 4.7GHz (each test required different settings for stability)
ASRock OC Formula
G-Skill Trident X F3-2400C10D-16GTX 16GB (2x8GB) 2400MHz
Corsair H100i
DMM is a DigiTech QM1571
Aida64
I ran Aida64 for 2 hours (my normal test time although Aida64 recommends 12 hours) with only Stress FPU selected (FPU stressing means AIDA64 System Stability Test will use a floating-point calculation task that stresses the FPU part of your processor. Modern processors all have an integrated FPU, and from all the components that are integrated, the FPU is the most complex one. Hence stressing only the FPU actually stresses most of your processor, and usually drives the processor to its maximum temperature)
Prime95
I ran Prime95 for 5 hours with the settings outlined in the Complete Overclocking Guide: Sandy Bridge & Ivy Bridge | *ASRock Edition* thread. People might complain that these are not "optimal" settings but they are what most people on this site who have this board would use.
Voltage (recorded with a DMM)
Aida64 requires slightly less voltage than Prime95.
Temperature
Aida64 causes higher temperatures
Conclusion
I have been overclocking CPUs for a number of years and I have never used Prime95 to test the stability of an overclock. I have never had a system crash that has passed a few hours stressed with Aida64 (and before that when it was Everest) I have, however, helped many people who have run Prime95 for many hours only to have their systems crash when they fire up a game (for example)
Test bench:
ASRock OC Formula
Corsair H100i
Aida64
Prime95
Temperature
Conclusion
