I am putting together planning on converting all my GPU's in my mining rigs to water for better temp control. Due to lack of support on some cards for gpu blocks i am leaning at using the Kraken G12 kits on all my GPU's.
My question is what is the round format that the AIO's use for locking into the brackets called?
I am trying to figure out this format, to see if there is a universal waterblock out that i can use instead of AIO's watercool the gpu in combination of the Kraken g12 kit. I just cant seem to find the name of this round format....
My 2 options im playing with are the following...
Kraken G12 + H105 AIO
or
Kraken G12 + Universal
The other issue im trying to figure out is the use of all the fans and water pumps that come with running many of these kits on lets say a 8 GPU rig. Thats 3 fans and 1 pump wire per GPU, so 32 wires needing controlled and the motherboard only has 3 fan plugs.
or
